Trimming the exhaust vent
A project log for I want a Laser Cutter!
My Home Laser Cutter Journey
Hari WigunaHari Wiguna 12/24/2018 at 17:250 Comments
The exhaust vent inside the K40 juts in quite far and actually obscures the laser path when Y is zero.
Unfortunately taking out this vent to trim it on the bandsaw require removal of the gantry that is in the
way, in turn this would require re-aligning mirrors.  I decided to do it differently.
       Success!
Ooops...
Incidentally, later I discovered that I did not trim enough to clear a 3D printed air assist nozzle and had to trim for the second time.  So, if you decide to do this, be more generous in trimming. :-)
