I've seen the need for different voltages when performing tests or making a prototype. With this unit you only need one bench top power supply with one output.
I've just bougth RND 320-KA3005P (30V, 5A and one output). During development or test several voltages may be needed. The unit takes 30V in and distributes it to several high current DCDC converters with one output for each voltage.
Each output shall have its own display that shows the actual voltage and ouput current.
Files
LT8609 - Datasheet.pdf
Adobe Portable Document Format -
1.39 MB -
11/25/2018 at 17:45
