Big gear design fixed
A project log for FAROSH
Fully Automated Revolving Object Storage Hub
zoZoƩ 12/09/2018 at 15:290 Comments
Thanks to Daniel Watson @is0explore@twitter.com I fixed the big gear geometry. https://twitter.com/is0explore/status/1071764065645748225
Turns out the Gear library I am using creates weird geometry if the bore of a gear is too close to its diameter. As a workaround, I create a gear with a small bore and then cut out the inner part. It's being printed now!
