The app is now live in the Android Market! If you were wanting to try out this application, but for whatever reason didn't want to download the apk from Github and side load it then today is your lucky day.
You can download it from the play store using this link: Play Store Link. Or if you have a Barcode Scanner you can scan the QR below to open up the Play Store.
you made a really good application it helped me a lot with my website where i post apk file you can see here https://pikashowdownload.in
