Front panel
A project log for tv-remote-elderly
Christmas gift for my 90+ granny: TV remote with big buttons
christoph-tackChristoph Tack 01/13/2020 at 19:520 Comments
Self adhesive print
This can easily ordered by online photo print services.  Probably such a label will start to loosen by the edges.  It might get dirty.  It would still require for the housing to be milled.
PCB Front panel
Front panel can be drilled, filed until the PCB fits.  It doesn't have to be a perfect job.  It will be covered anyway by the PCB front panel.  The labeling can be done in silkscreen.  Silkscreen is a high quality print, it will not wear or tear off.
First job, convert the dwg design files to dxf using cloudconvert.  Then clean up and scale the front panel in Librecad.  Then it can be imported in EasyEDA.
Front panel design
The final front panel will be ordered in yellow soldermask.  It will be ordered after Chinese New Year because now they charge me $43 if I don't want green soldermask.
