#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 13); // RX, TX
#include           //https://github.com/esp8266/Arduino
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include "WiFiManager.h"          //https://github.com/tzapu/WiFiManager
int count=0,i,m,j,k;
int t,t1,t2,t3;
int outputpin= A0;//ds18b20
int onoff=0;
float tempc;  //variable to store temperature in degree Celsius
float tempf;  //variable to store temperature in Fahreinheit
float vout;//temporary variable to hold sensor reading
#define switch D6 // your relay switch
//////////////////////////////////////// ALL DECLARATIONS for CLOUD //////////////////////////////
const char* host = "api.thingsio.ai";                                 // OR host = devapi2.thethingscloud.com
const char* post_url = "/devices/deviceData";       // OR /api/v2/thingscloud2/_table/data_ac
const char* time_server = "baas.thethingscloud.com";             //this is to convert timestamp
const int httpPort = 80;
char timestamp[10];
WiFiClient client;
void configModeCallback (WiFiManager *myWiFiManager)
  Serial.println("Entered config mode");             //*-*-*-*-*-*-*-*-*-*-*-*-*-*if control enters this function then net is not connected
  Serial.println(WiFi.softAPIP());                  // "WiFi.softAPIP() is for AP" , "WiFi.localIP() is for STA",
  Serial.println(myWiFiManager->getConfigPortalSSID());             //if you used auto generated SSID, print it
/////////////////////////////////////// TIMESTAMP CALCULATION function///////////////////////////////////////
int GiveMeTimestamp()
  unsigned long timeout = millis();
  while (client.available() == 0)
    if (millis() - timeout > 50000)
      client.stop();
      return 0;
while (client.available())
        String line = client.readStringUntil('\r');                    //indexOf() is a funtion to search for smthng , it returns -1 if not found
        int pos = line.indexOf("\"timestamp\"");                       //search for "\"timestamp\"" from beginning of response got and copy all data after that , it'll be your timestamp
        if (pos >= 0)
          int j = 0;
          for(j=0;j<10;j++)
            timestamp[j] = line[pos + 12 + j];
void setup()
  pinMode(switch,OUTPUT);
  Serial.begin(115200);     //(19200,SERIAL_8E1) - data size = 8 bits , parity = Even , stop bit =  1bit
  mySerial.begin(115200);
  WiFiManager wifiManager;
  wifiManager.setAPCallback(configModeCallback);
  if(!wifiManager.autoConnect("DDIK Makadia","kidd123456789"))                   //wifiManager.autoConnect("AP-NAME", "AP-PASSWORD"); (OR) wifiManager.autoConnect("AP-NAME"); only ID no password (OR) wifiManager.autoConnect(); this will generate a ID by itself
    Serial.println("failed to connect and hit timeout");     //control comes here after long time of creating Access point "NodeMCU" by NodeMCU and still it has not connected
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(1000);
  //if you come here you have connected to the WiFi
  Serial.println("connected...");
void loop()
  int analogValue = analogRead(outputpin);
/////////////////////////////////////// SEND THE QUERY AND RECEIVE THE RESPONSE///////////////////////
        t1=(analogValue/1024.0) *5000;
        Serial.print("temp: ");
        Serial.println(t1);
        t2=(t1/10);
        Serial.print("celc: ");
        Serial.println(t2);
        if(t2<30) //set your temp
          digitalWrite(switch,LOW);
          onoff=0;
          Serial.println("OFF");
        else if(t2>30) // set your temp
          digitalWrite(switch,HIGH);
          onoff=1;
          Serial.println("ON");
  Serial.print("connecting to ");
  Serial.println(host);                          //defined upside :- host = devapi2.thethingscloud.com or 139.59.26.117
///////////////////////////////////// TIMESTAMP CODE SNIPPET /////////////////////////
  Serial.println("inside get timestamp\n");
  if (!client.connect(time_server, httpPort))
    return;                                                        //*-*-*-*-*-*-*-*-*-*
  client.println("GET /api/timestamp HTTP/1.1");                            //Whats this part doing, i didnt get
  client.println("Host: baas.thethingscloud.com");
  client.println("Cache-Control: no-cache");
  client.println("Postman-Token: ea3c18c6-09ba-d049-ccf3-369a22a284b8");
  client.println();
  GiveMeTimestamp();                        //it'll call the function which will get the timestamp response from the server
  Serial.println("timestamp receieved");
  Serial.println(timestamp);
// Use WiFiClient class to create TCP connections
  if (!client.connect(host, httpPort))            //host = devapi2.thethingscloud.com , port = 80
    Serial.println("connection failed");                  // *-*-*-*-*-*--*-*-*-*-*-*-*-*-*-*-*-*-
    return;
  client.print("Content-Length: ");
  client.println();
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
  Serial.println("***********************************************");
  Serial.println();
  Serial.println("closing connection");
  Serial.println("inside ThingsCloudPost");
  int timestamp1 =0;
  timestamp1 = 1542800778;
  String PostValue = "{\"device_id\": xxxxxxx, \"slave_id\": 1";
  PostValue = PostValue + ",\"dts\":" +timestamp;
  PostValue = PostValue +",\"data\":{\"Celc\":" + t2 +",\"Fan\":" + onoff +"}"+"}";
  Serial.println(PostValue);
//////////////////////////////// try to connect to server again and POST the data on the cloud //////////////////////////
    return;
  client.print("POST ");
  client.print(post_url);               /// POST api/device-datas         HTTP/1.1     Host: baas.thethingscloud.com      Content-Type: application/json        Cache-Control: no-cache
  client.println(" HTTP/1.1");           //Authorization:          Content-Length:
  client.print("Host: ");
  client.println(host);
  client.println("Content-Type: application/json");
  client.print("Authorization: Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.IjViZTc5ZjRiNDAyYjlkNGI5MDdiZGRmZCI.hBa2XTagbf56p_E83PeMZHaoJO4EUrbwGcmWTU0j0-w");
  client.println();
  client.println(PostValue.length());
  client.println();
  client.println(PostValue);
//////////////////////////////////POSTING the data on to the cloud is done and now get the response form cloud server//////////////////
      client.stop();
      return;
  Serial.println("Response From Server");
  while(client.available())
    String line2 = client.readStringUntil('\r');
    Serial.print(line2);
  Serial.println("//////////////////////    THE END     /////////////////////");
  delay(3000);
