Floor cleaning sandals
A project log for Silly hardware wishlist
Too simple for a project page & which may never happen.
lion-mclionheadlion mclionhead 01/13/2019 at 04:051 Comment
Sandals with some kind of reactive sole similar to magic erasers.  They would react very slowly to gradually clean large areas of floor as you walked.  The idea is heavily trafficked areas of carpet & linoleum always turn black.  The mane cause is rubber wearing off of black sandals.  The lion kingdom switched to tan sandals with some improvement, but surely if anything can be rubbed off a sandal, it could be a detergent of some kind which makes dirt particles in the carpet looser than the rubber particles in the sandal.  Then, the process would be the carpet rubbing dirt onto the sandal instead of the sandal rubbing dirt onto the carpet.
There are mopping slippers
https://www.amazon.com/Microfiber-Slippers-Unisex-Cleaning-Stripe/dp/B07M9N8QVL/
But they're not practical for daily use.
The easiest way to get started is hot gluing a temporary sheet of white rubber on existing sandals.
thirusamig wrote 12/14/2021 at 18:25 point
Floor cleaning like https://www.vacuumcleaneradviser.com/how-to-steam-clean-couch/ is really boring work and nice sandals will make it little easier.
