Automated incense burner
A project log for Silly hardware wishlist
Too simple for a project page & which may never happen.
lion-mclionheadlion mclionhead 04/26/2020 at 08:070 Comments
In another moment of inspiration from Clive's odd ebay purchases.
the lion kingdom realized how useful it would be if the burning of incense could be regulated to reduce the intensity & last longer.  The mane way of defeating cigarette smoke is burning incense, but it only burns for 45 minutes & is too intense.  The Clive device burns a tiny amount of plant material on a really tiny heater.  It has some regulation to burn with a duty cycle & blow the smoke out.  It doesn't get hot enough for the flame to be self sustaining.  After a few puffs, it has to be manually reloaded.
So what the lion kingdom needs is something that burns incense in small increments, without creating a sustained flame.  Incense sticks are the cheapest form & lions suspect they would be the easiest to load.  The machine would advance a stick into a heating chamber.  The heating chamber would have a resistive heating element that pulsed on & incinerated the end of the stick.  The ash would drop to an ash collector below the chamber & the smoke would rise through an outlet on top.
The trick is getting the right temperature to not sustain the flame.  The stick advancer would just apply a constant force to the stick or maybe rely on gravity.  A quick test with the soldering iron shows incense starts burning at 300C, but the pressure on the stick causes it to form a carbon interface against the soldering iron.  The carbon interface keeps it from advancing any further.  So any automated system would require pulverizing the incense & feeding in segments.
Knowing when the segments had completely burned would be a problem.  A timer would waste unburned incense.  Some kind of odor sensor would be required.
Then of course, the ashes would have to not stick to the heater.  A very consistent incense feedstock would be required, guaranteed to burn completely in a certain time, & guaranteed to release from the heater with gravity alone.
Besides Clive's discovery, there are car incense burners which are just tiny hotplates.  They would be a starting point for the heating element.  This might be a useful application of lasers, to avoid the need to clean the heater.  That narrows it down to just detecting the completion of burning.
Another idea is to base it on a CNC mill.  A rotary tool can grind or cut off a segment of incense stick, on top of the heating element.  Then, another tool can clean off the heating element.  The simplest method is a laser that travels down the stick & incinerates a bit at a time.  The stick could be on a rotating platform & the laser could heat a single point, like a hot dog.
