Wi-Fi Hotspot, OLED display and 3D printed case
A project log for Raspberry PI wireless Telescope Control
Advanced SkyFi 3 replacement for Celestron
chrisg71ChrisG71 12/26/2018 at 22:152 Comments
I am a little bit behind with documentation, but in the meantime I finished the configuration for the Wi-Fi Hotspot, added an OLED display and created a 3D printed case.
Here I am running a script which shows the current GPS data on the OLED.
Clear sky. First time I could really test my creation. You can see the USB cable with the red ring connected to the hand controller and the PI showing current time and GPS coordinates.
(still need to finish the script to set location as well. I would like to combine this with the hotspot enabled.)
djhnsn999 wrote 03/31/2019 at 17:27 point
Nevermind I found it.  I used the dropbox sdcard image and didn't import the git files.
djhnsn999 wrote 03/31/2019 at 17:20 point
Can you add instructions or a copy of the script for the oled display?
