Back to basics
A project log for Hedgehog Feeder
Hedgehogs in the UK are classed as an endangered species. For this reason I have chosen my final year project to be a hedgehog feeder.
Abigail SmithAbigail Smith 02/19/2019 at 15:440 Comments
After some time off for exam preparation, I back to focusing on the hedgehog feeder.
This project is unfamiliar territory for me, so it takes me a while to get back into the swing of things.
Currently trying to code my project to weigh the hedgehog and if the weight falls in a specific range, this will turn the stepping motor. Sounds simple but the load cell is not 100% accurate and changes weight slightly even when a constant weight is applied, let alone when a hedgehog is shuffling about on it.
Need to do a bit more digging in similar codes...
