Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Events Hackerspaces Profiles Hackaday.com Tindie Marketplace Remoticon
Sign up Log in
Raspberry Pi IOT module
The module is supposed to handle power management, control peripheral devices and in addition add GSM and GPS functionalities
madivakmadivak
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
274 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
274
0
274
1
Team (1)
  • madivakmadivak
Join this project's team
hardware
ongoing project
iot raspberrypi embedded systems engineering wireless systems gps power systems Altium pcb manufacturing prototype Robust Systems
This project was created on 12/09/2018 and last updated 2 years ago.
Description
To enable The raspberry Pi function as an IOT device a couple of things needed to be added which include: GSM chip, GPS and on top of that added some few functionalities among them supplying power to various components while monitoring consumption and remote control of peripheral devices.
Project Logs
Collapse logs
  • Raspberry PI IOT Module Testing (Mounted)
    madivak • 12/09/2018 at 19:28 • 0 comments
  • Raspberry Pi IOT module Manufactured PCB
    madivak • 12/09/2018 at 19:27 • 0 comments
  • Raspberry Pi IOT MODULE PCB DESIGN
    madivak • 12/09/2018 at 19:26 • 0 comments
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
4G (100 mbps down/ 50 mbps up) – Ultra fast internet connectivity for your Raspberry Pi, excellent for large downloads and video streaming.
Project Owner Contributor
IoT Bit 4G & LTE Hat for the Raspberry Pi
Altitude TechAltitude Tech
This is a placeholder, because I can't get it out of my head.
Open Source Compute Module
JarrettJarrett
Pixhawk Flight Control Unit based autopilot with Raspberry Pi Computer Module 3 and all other requied sensors, modules built-in.
Drone Autopilot with Raspberry Pi CM3 .
Tomi PiriyevTomi Piriyev
Industrial Grade IoT Hardware for the Raspberry Pi
IoT Module for Raspberry Pi
NateNate
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "Raspberry Pi IOT module", please tell us the reason.
Send message
Remove Member
