OLED runtime test in progress
A project log for Home environment monitor
Yet another wireless network of environmental sensors in a home
TundraTundra 12/18/2018 at 11:490 Comments
OLED runtime test in progress. It's definitely going to have a shorter runtime than the eInk display did. Currently at 3.84v after 23.75 hours. The eInk run took 38.6 hours to drop from 4.2v to 3.84v. If the ratios hold this means 51.68 hours to stop of serial data and 49.8 hours to stop of meaningful battery voltage readings. We will see how accurate that prediction is.
