Not A Hack
The Hackaday card game.
The card game 'Not A Hack' challenges players to create the best hack. Status: Testing
Not a hack Rules (3 to 5 players)
TLDR Overview
  1. Players take turns voting on completed hacks built by other players.
  2. If you get “banned” your point total is finalized and you must wait for play to finish.
  3. When two unbanned players remain a final hack-off round ends the game.
  4. Whoever has the highest point total at the end of the game wins.
Complete Rules
Create two card piles, black hack cards, and white component cards.
Remove all the white new account cards from the white component card pile. Each player is given one white new account card. Shuffle enough white new account cards back into the white component card pile so that there is one fewer than the number of people playing.
Each player draws ten cards from the white component card pile.
Turn 1: Choose one person to draw from the black hack pile, if the card is a hack, everyone plays components to complete the hack.
Hack cards usually require one orange component card and one pink modifier card to complete. If a player is missing a required card they may discard a card from their hand to the white component discard pile and draw a new card from the white component card pile. Repeat until they receive a card that completes the hack.
The person who drew the black hack card then reads each submitted hack combination and decides a winner who keeps those white component cards as points. Set these winning cards in front of that player. Each player draws white component cards to replace their used white component cards.
Following turns: Take turns drawing from the black hack pile until two players remain.
Action cards drawn from the black hack pile are played immediately. If a player draws a negative action card they lose the amount of points specified on the card. Set this card in front of that player.
If a banned card is drawn the person is out of the game and their points are finalized. A banned card can be countered with a new account card. Discard the black banned card to the black discard pile and discard the white new account card to the white discard pile.
Action cards drawn from the white component pile can be used at anytime. If a player draws a positive action card they gain the amount of points specified on the card. Set this card in front of that player.
A player can use a white “steal” card to take a winning hack from any unbanned player. Set these winning cards in front of that player. Discard the used white steal card to the white discard pile.
If either black or white card pile runs out, use a shuffled discard pile to replace it.
Winning: When two players remain, enter the final hack-off round. Any player draws from the black hack card pile until a hack card appears, ignoring other card types. Both players play white component cards and all “banned” player(s) vote on the winning hack. At the conclusion of the hack-off, the player (including banned players) with the highest (or least negative) point total wins. In case of a tie repeat the hack off by drawing a new black hack card.
  • 30 × Hack cards
  • 10 × Banned cards
  • 30 × Negative action cards
  • 10 × Steal hack cards
  • 100 × Component cards
View all 7 components
  • Standard Card Sizes
    Richard Hogben01/17/2020 at 19:06 0 comments
    Resize to 3.5" x 2.5"
  • First Play-through & Testing
    Richard Hogben12/14/2018 at 18:45 0 comments
    The first version was laser printed and cut by hand, second run real cards with curved corners!
    Picked out some cards to correct / change during play tests. These will be corrected in Illustrator before the next print.
    We gave the black cards an inverted back color to tell the two piles apart.
    In finalizing the directions, originally there wasn't a discard pile. We tried it during one of the games and not recycling the cards constantly seemed to work a bit better.
View all 2 project logs
Sophi Kravitz wrote 02/11/2019 at 20:37 point
I played this game and it was hilarious. I need to print it out for home even though as @Yann Guidon / YGDES says we're playing the original right now. Meta.
Yann Guidon / YGDES wrote 02/11/2019 at 22:48 point
muhahahahahaha
Yann Guidon / YGDES wrote 01/11/2019 at 06:30 point
Wait...
Aren't we all playing the ORIGINAL un-emulated version right now ?
Tillo wrote 01/10/2019 at 13:24 point
could be done with an arduino
deʃhipu wrote 01/10/2019 at 13:53 point
nah, a 555 would be enough
Richard Hogben wrote 01/10/2019 at 15:25 point
Yann Guidon / YGDES wrote 01/11/2019 at 06:28 point
A SPDT relay is more than enough !
damfle wrote 01/11/2019 at 07:13 point
Use a 555 timer !
Yann Guidon / YGDES wrote 01/11/2019 at 07:18 point
damfle : are you siding with ꝺeshipu ??? traitor !
Elliot Williams wrote 12/17/2018 at 13:05 point
Hah!  Brilliant.  Sadly, not a hack.
