Base Plate and Top Plate
A project log for 16 Inch 7-segment LED
This will be a giant LED numeral made with neopixels.
David WheelerDavid Wheeler 12/18/2018 at 02:580 Comments
Tonight's progress: a base plate with mounting holes and access holes.  Also a top plate with mount holes.
The design is coming together quickly.  I should probably pull the trigger on some electronics orders soon.
