I have almost finished the ALU wiring - I only need to connect the output to the data bus and add some proper LEDs. A quick test shows that it is working as expected, even if the wiring is a mess. Here it is calculating 17 - 14.
I'll be glad to move onto a different module. IIRC Ben does the RAM module next, so that's prolly what I will do...
