Desolder time
A project log for Evil USB Hub
I randomly found an USB hub with two device ports. While playing with MaMe82's P4wnP1 A.L.O.A.
tilloTillo 01/01/2019 at 14:180 Comments
Well to fit in Pi Zero into that case, some LEDS need to go.
As well as the switch. So I unsoldered stuff. Unfortunatly some through hole contacts fell out. Thank god, they weren't critical for  the project. Actually it was even useful, since i could use the holes to put the wires for the USB data lines.
