Solenoid valve ordering info!
A project log for FORCE - Force Output of Rodent Calibrated Effort
This dual-force cell monitor and reward dispenser is used to run rodent operant behavior in which animals learn to work for rewards.
bridget.matikainen-ankneybridget.matikainen-ankney 09/23/2019 at 13:540 Comments
We order two parts from the Lee Company - the solenoid valve (LHDB0342115H LEE HDI SOV, PI-2P-3.3V-SI), and the manifold it sits in (LFMX0524000A MANIFOLD-1X HDI-PI-2 PORT).
https://www.theleeco.com/whats-new/ultra-miniature-2-port-hdi-solenoid-valve1/
https://www.theleeco.com/products/electro-fluidic-systems/solenoid-valves/control-valves/standard-2-port-plug-in-style-manifolds/
