Continuously monitoring rodent work output onto force cell
A project log for FORCE - Force Output of Rodent Calibrated Effort
This dual-force cell monitor and reward dispenser is used to run rodent operant behavior in which animals learn to work for rewards.
bridgetmatikainen-ankneybridget.matikainen-ankney 01/15/2019 at 19:320 Comments
Currently ARROW continuously monitors (displayed on the LED screen of an Adafruit Mini TFT with Joystick Featherwing) and outputs (via BNC) force cell readings on the active (reward-dispensing) and inactive (non-reward-dispensing) force cells. We are in the process of adding pre-programmed fixed and progressive ratio behavioral paradigms; stay tuned!
