Initial Planning stage 2
A project log for Smart glasses: Notifications and heart-rate
(Inspired by work from Alain Mauer)
virgilius1995Virgilius1995 01/29/2019 at 12:440 Comments
Relevant software code found online unfiltered and unedited.
Since I am new to Arduino development I’ve gathered the following scripts from various online projects that have some code relevant to the project. I plan on using this code as a template for my own code to streamline the process since while I’m qualified in C++, I have no experience with Arduino. I’ve linked the original pages PLEASE SUPPORT THE ORIGINAL POSTERS
Receive Notification information (Arduino) (source: https://create.arduino.cc/projecthub/geny-studio/notification-iot-using-neopixel-and-smartphone-945e81?ref=user&ref_id=114809&offset=0)
#include <SoftwareSerial.h>
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN            10
#define NUMPIXELS      24
#define rxPin 4
#define txPin 3
SoftwareSerial BT(txPin, rxPin);
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 50; // delay for half a second
void setup() {
  BT.begin(9600);
  Serial.begin(9600);
  pixels.begin(); // This initializes the NeoPixel library.
void loop() {
  if (BT.available() >0)
    //Receive values from Notiduino Android App whenever it gets notification messages
    //Use semicolon and comma as seperator to retrieve header message and RGB color value
    String BT_receive_data = BT.readStringUntil((char)3);
    String Message_Head = getValue(BT_receive_data, ';', 0);
    String ColorValue = getValue(BT_receive_data, ';', 1);
    int R = getValue(ColorValue, ',', 0).toInt();
    int G = getValue(ColorValue, ',', 1).toInt();
    int B = getValue(ColorValue, ',', 2).toInt();
    Serial.println(Message_Head);
    Serial.println(ColorValue);
      for (int i = 0; i<NUMPIXELS; i++)
        pixels.setPixelColor(i, pixels.Color(R, G, B)); // Moderately bright green color.
        pixels.show(); // This sends the updated pixel color to the hardware.
        delay(10);
        pixels.setPixelColor(i, pixels.Color(0, 0, 0));
#pragma region get Value
String getValue(String data, char separator, int index)
  int found = 0;
  int strIndex[] = { 0, -1 };
  int maxIndex = data.length() - 1;
  for (int i = 0; i <= maxIndex && found <= index; i++){
    if (data.charAt(i) == separator || i == maxIndex){
      found++;
      strIndex[0] = strIndex[1] + 1;
      strIndex[1] = (i == maxIndex) ? i + 1 : i;
  return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
#pragma endregion
Receive Heartrate information(Arduino)(Source: https://pulsesensor.com/pages/code-and-guide)
Display heart rate (Arduino) (Source: http://www.xtronical.com/basics/heart-beat-sensor-ecg-display/)
#define OLED_Address 0x3C
Adafruit_SSD1306 oled(1);
int x=0;
int lastx=0;
int lasty=0;
int LastTime=0;
bool BPMTiming=false;
bool BeatComplete=false;
int BPM=0;
#define UpperThreshold 550
#define LowerThreshold 500
void setup() {
  oled.begin(SSD1306_SWITCHCAPVCC, OLED_Address);
  oled.clearDisplay();
  oled.setTextSize(2);
void loop()
  if(x>127)
    x=0;
    lastx=x;
  int value=analogRead(0);
  oled.setTextColor(WHITE);
  int y=60-(value/16);
  oled.writeLine(lastx,lasty,x,y,WHITE);
  lasty=y;
  lastx=x;
  // calc bpm
  if(value>UpperThreshold)
    if(BeatComplete)
      BPM=millis()-LastTime;
      BPM=int(60/(float(BPM)/1000));
      BPMTiming=false;
      BeatComplete=false;
    if(BPMTiming==false)
      LastTime=millis();
      BPMTiming=true;
  if((value<LowerThreshold)&(BPMTiming))
    BeatComplete=true;
    // display bpm
  oled.writeFillRect(0,50,128,16,BLACK);
  oled.setCursor(0,50);
  oled.print(BPM);
  oled.print(" BPM");
  oled.display();
  x++;
Display notifications (Arduino)  and Display time (Arduino) (source: https://circuitdigest.com/microcontroller-projects/build-an-arduino-smart-watch-by-interfacing-oled-display-with-android-phone)
#include<SoftwareSerial.h>
SoftwareSerial Serial1(10, 11);
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "Adafruit_SSD1306.h"
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
String str = "";
byte h = 0;
byte m = 0;
byte S = 0;
String dmy, time, network, battery, inNumber, s;
byte centerX = 24;
byte centerY = 39;
byte Radius = 24;
double RAD = 3.141592 / 180;
double LR = 89.99;
void showTimeAnalog(int center_x, int center_y, double pl1, double pl2, double pl3)
  double x1, x2, y1, y2;
  x1 = center_x + (Radius * pl1) * cos((6 * pl3 + LR) * RAD);
  y1 = center_y + (Radius * pl1) * sin((6 * pl3 + LR) * RAD);
  x2 = center_x + (Radius * pl2) * cos((6 * pl3 - LR) * RAD);
  y2 = center_y + (Radius * pl2) * sin((6 * pl3 - LR) * RAD);
  display.drawLine((int)x1, (int)y1, (int)x2, (int)y2, WHITE);
void digitalClock()
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(60, 20);
  display.println(dmy);
  display.setTextSize(2);
  display.setCursor(60, 30);
  display.println(time);
  display.display();
  delay(2000);
External Software used(TBD):
