If you turn on/off 3 times then they reset themselves
A project log for ESP32-MeshKit custom RGB LED Lamps
Use this RGB Leds that are in your garage to build your own Lights. As simple as Leds, Ω and soldiering (To be safe max. 30 mA per GPIO)
Martin FasaniMartin Fasani 09/19/2019 at 05:560 Comments
https://twitter.com/martinfasani/status/1174551238303784960
In my home every 2 weeks they enter in this modus. It happens because my wall switches are very old.
It’s a pity that so far I didn’t found a way to disable this 3 on/off reset. Anyways it’s very easy with the Mesh app to make them join your network again.
Note: For concrete lamps you need to get it out to make a successful Bluetooth connection. It seems WiFi passes through cement but Bluetooth not so good.
