Myriad X + i.MX 8M SoM | DepthAI Vision Module
A project log for Luxonis DepthAI
Bringing the power of the Movidius Myriad X to Raspberry Pi (and your design!)
BrandonBrandon 08/07/2019 at 22:253 Comments
Hey everyone,
So the next step on the path to CommuteGuardian is a SoM for the Myriad X and the i.MX 8M.  This will allow us to drop in a full system running a modern Linux, and with the VPU power of the Myriad X, into our Commute Guardian prototype (and hopefully, final product).  The data path is shown below:
And it will allow you to do the same for your application!  Think of this as like the 'Pro' version of DepthAI for Raspberry Pi.  As it allows it to drop directly into your prototype or product, with the wicked power of the i.MX 8M backing up the visual processing prowess of the Myriad X.
So we just started about a week ago, and here are some layout views to show progress so far:
Thoughts?  Questions/ideas/comments welcome!
Cheers,
The Luxonis Team!
Brandon wrote 08/15/2019 at 16:04 point
Also update the main page to have this on it:
https://hackaday.io/project/163679/details/
Thoughts?
Thanks,
Brandon
Tegwyn☠Twmffat wrote 08/09/2019 at 07:26 point
Please could you produce some kind of flow chart showing the 3 cameras and where the data from Myriad X goes WRT the carrier board? It's not clear what the i.MX 8M does and how it will communicate with the Pi. Thanks!
