I decided to make second revision of this project, with PCB trace antenna. I had to match impedance and length and this was skipped in first version. This module works a lot more reliable :)
![](https://cdn.hackaday.io/images/2223991573230147360.jpg)
A project log for WiFi to 433 MHz bridge
Toggle 433MHz sockets using network connected smartphone
