Project Goals
A project log for Dropsonde Micro
A bite sized dropsonde for taking atmospheric measurements from low to moderate altitude.
connor-huffineConnor Huffine 02/13/2019 at 05:560 Comments
The idea for this sonde is a minimal cost system that transmits data to ground from at least 5000ft. The device should be recoverable and reusable.
The desired measurements are as follows:
P/T/H can be accomplished with a single chip such as the BME280.
Wind measurements can be derived with some accuracy using a GPS and integrating the movement of the system as it falls.
The descent rate of the system will provide the time for GPS movement, but with some caveats; the slower the sonde descends, the more it will drift. A balance needs to be struck between ease of retrieval and  measurement quality.
