SinCos encoders and a tiny wheel
A project log for Open FFBoard
A modular and open source force feedback interface and motor driver for DIY wheels and controllers
yannick-gigawipfYannick (Gigawipf) 06/25/2020 at 19:252 Comments
While working on the next pcb version one task was to improve the support for analog sine/cosine encoders.
With sincos encoders we have the option to use high resolution absolute encoders and in the next version hopefully even with differential inputs for less noise.
For testing i made a few AS5115 based magnetic encoders and mounted a magnet to the shaft of a drone motor as a test setup.
That gave me the idea to make a tiny ffb wheel :)
brainstormi wrote 12/30/2020 at 14:04 point
Could you show how you attached the magnet to the motor shaft?
Edson wrote 08/11/2020 at 11:30 point
hi, so how is the project going? its everything ok or you're found some problems on the way?
