Biquad filter noise
A project log for Yet Another Doppler Direction Finder w/ Teensy DSP
An update on WA2EBY's May/June 1999 QST Homebrew DDF/Radio Direction Finder
martinMartin 03/30/2019 at 05:550 Comments
I noticed that using the test configuration I get a lot of variation in raw heading info.  Fortunately I didn't include a test point.  After soldering to the DAC pin and attaching the 'scope I saw the problem immediately - noise.  Doing a little research on the PJRC site I found that biquad noise has been an issue before.  I may drop down to an FIR filter to quiet things down.  That may mean adding some prefiltering to the FIR filter to get the requisite brick wall filter performance.
