The hope was to ship the Novasaur with some form of BASIC on board. There is just enough space on the B: drive to fit a 1970's era 8k BASIC. The more capable MBASIC 5.21 can be loaded to the A: drive, but at over 24k it won't ship in the ROM.
The initial effort was bringing up the original Microsoft Altair BASIC (circa 1978). There is a source code available, but this proved to be defective. The alternative was the IMSAI 8K Floating-point BASIC (circa 1977). This source code was more successful!
The image above shows the following BASIC program running at actual speed:
10 FOR X=0 TO 2*PI STEP PI/15
20 PRINT SPACE(INT(SIN(X)*36+36));"*"
30 NEXT X
There are still some optimizations to be made in terms of console integration and the software restarts. The performance isn't too bad though considering the CPU is running at 1/5th the speed of the original hardware.
Alastair Hewitt
