Installing the Cherry switches
03/06/2019 at 21:12 • 0 commentsInstalling the Cheery switches.
Metal plates for keys
03/06/2019 at 20:57 • 0 commentsLaser cut metal plates. This is the left side, the bottom right hole is for the mouse buttons.
Unfortunately they have made a mistake cutting two times only one side.
This is what I've ordered.
PS/2 Mouse for Tests
03/06/2019 at 20:52 • 0 commentsWith the correct wiring, QMK can support a PS/2 Mouse. In this way with just one USB cable two devices could be used.
In the final product instead of a mouse a trackball will be used. -
Teensy2++ board
03/06/2019 at 20:48 • 0 commentsTesting done with a Teensy2++ board. Later a Teensy2 will be used.
Test board
03/06/2019 at 20:43 • 0 commentsBefore building the keyboard I've done some tests with this protoboards.
