Two months.
A project log for SyncMaster 2494 monitor repair.
Air wired HV SMD ballast resistor to rebuild a carbonized PCB.
daren-schwenkeDaren Schwenke 05/10/2019 at 23:230 Comments
So far so good.  I don't think it has ever been powered down since the repair, barring the occasional thunderstorm.  So it seems that this did the trick.
The next post will be when it eventually eats itself.
It is a cold cathode back-light after all and has been powered on at least 8-12 hours a day since I bought it 10 years ago.   So... see you in 2-4 years?
I really like this monitor actually.  One can only hope.
