First Purple Panels for Clouds
A project log for Mutable Instruments Clouds PCB Panel
Creating a custom front panel for the assembled Eurorack module.
richard-hogbenRichard Hogben 03/28/2019 at 22:470 Comments
The purple solder mask is as dark as I expected. I would probably remove it from the back next time to give it better translucency.
The white silk screen is offset a bit, I would probably not run the solder mask behind it to avoid the edge alignment.
The svg conversion went well and text looks good.
Just some offset white silk screen here.
I'm going to test mount in a retail case, then on to the next set of colors.
