Software
A project log for RGBW Controller Shield
RGBW analog or digital LED stripe controller whit smooth transitions.
eduardoEduardo 04/27/2019 at 21:410 Comments
Brief revision of the serial console.
Serial commands:
help:
__________________________________________________
|                - RGBW v4.0 -                   |
|________________________________________________|
|Commands:                                       |
|    onoff   allon            alloff             |
|    data    cycle            resetsettings      |
|    help    savecolor[1-8]   callcolor[1-8]     |
|    wt      levelw[0-100]    lramp[0-10000]     |
|    rt      levelr[0-100]    lcramp[0-10000]    |
|    gt      levelg[0-100]    lstay[0-30000]     |
|    bt      levelb[0-100]    ldimm[0-99]        |
|Tuners:                                         |
|      r+         g+          b+         w+      |
|      r-         g-          b-         w-      |
|     stay+      ramp+      cramp+      rgb+     |
|     stay-      ramp-      cramp-      rgb-     |
|Colors:                                         |
|  red   ltgreen  green   magenta  cyan  white   |
|  blue  ltblue   orange  rgbwhite gold  violet  |
Provides this help frame with all the commands.
onoff:
Turn off fast and turn on to the last color.
allon:
All colors on to the highest level.
alloff:
All colors off.
data:
| Data:                                          |
|   White    |    Red    |   Green   |   Blue    |
|     0      |     255   |     0     |    255    |
|     0%     |     100%  |     0%    |    100%   |
|     Ramp      |   Cycle Ramp   |  Cycle Stay   |
|     300       |      1500      |     2000      |
Show this data frame.
cycle:
Start/Stop the cycle mode. It change the color from the 8 memory colors. It gives this frame:
|                   Cycle Mode                   |
|                       On                       |
resetsettings:
This reset all settings to the factory settings.
savecolor:
Save the current color to the desired position:
savecolor 4
callcolor:
Call the selected color:
callcolor 4
wt, rt, gt, bt:
Color toggle, it switch the selected channel.
levelw, levelr, levelg, levelb:
Level input, use to set a desired level in %:
levelw 74
It gives the next frame:
|              White Level:74%                   |
Can be seted from 0 to 100.
lramp:
Level ramp, use to set a desired time in ms:
lramp 300
It gives the data frame updated. Can be seted from 0 to 10000.
lcramp:
Level cycle ramp, use to set a desired time in ms:
lcramp 300
It gives the data frame updated. Can be setted from 0 to 10000.
lstay:
Level cycle stay, use to set a desired time in ms:
lstay 300
It gives the data frame updated. Can be setted from 0 to 30000.
ldimm:
Level dimmer, use to set a desired level in %, it gives the data frame updated. On cycle mode it gives this data frame:
| Data:                                          |
|     0      |     200   |     0     |    200    |
|     0%     |     78%   |     0%    |    78%    |
|     300       |      1500      |     2000      |
|                   Cycle On                     |
|                   Dimm:50%                     |
w+/- r+/- g+/- b+/-:
Increment/decrement the selected color
stay+/-:
Increment/decrement cycle stay time.
ramp+/-:
Increment/decrement ramp time.
cramp+/-:
Increment/decrement cycle ramp time.
rgb+/-:
Increment/decrement all colors.
red:
Set red color (r100%)
blue:
Set blue color (b100%)
green:
Set green color (g100%)
cyan:
Set cyan color (g100% b100%)
magenta:
Set magenta color (r100% b100%)
gold:
Set yellow color (g100% g100%)
orange:
Set orange color (g100% g14%)
violet:
Set violet color (r65% b100%)
ltgreen:
Set ltgreen color (g100% b9%)
ltblue:
Set ltblue color (g74% b100%)
white:
Set white color (w100%)
rgbwhite:
Set rgb white color (r100% g100% b100%)
Buttons:
Buttons have two push modes, short and long press: Button 1 on short press use the onoff command, showing the next frame
|                       On                       |
On long press use the wt command, showing the next frame
|                   White toggle                 |
|                       On                       |
Button 2 on short press change through the seven color mode, showing the next frame:
|                    Mode:1                      |
On long press use the cycle command, showing the next frame
|                   Cycle Mode                   |
|                       On                       |
IR Remote
When a signal is received this frame appears:
|               IR Signal Recieved               |
The IR functions are limited to the following commands:
