Bumps.
A project log for Parametric Box Generator
Populate two arrays and generate custom divided storage.
Daren SchwenkeDaren Schwenke 03/23/2019 at 15:390 Comments
The two bumps (spheres in the code) which are the latch and snap it closed could use to be slightly taller.
That's a bending interface and the force applied crosses layer lines, so a delicate balance must be struck.
<EDIT>
Fixed.  New source and rendered files are up.
</EDIT>
