LED drivers installed
A project log for UV Curing Chamber
A UV light curing chamber made with an old rack, some aluminum foil, and three 50W UV LEDS. An Arduino is used as a programmable timer.
Andrés Lopez PulzovanAndrés Lopez Pulzovan 08/29/2020 at 14:590 Comments
The three 55.6W drivers were installed. They connect to the mains through the relay, so that the LEDs are turned on or off by connecting the drivers to the mains.
