2019-03-31 Printed and assembled the coxas.
Unfortunately, I had designed the parts with enough clearance for a 0.2mm print but I decided to go with 0.3 at the last minute. So the slicer didn't round the values in my favor everywhere and I had to remove material with a knife to make the femur motor fit. Some screw holes even cracked as I was putting the screws in. It looks like it still holds for now but I definitely have to add more material around the coxas side tabs and maybe print in the other direction to make them stronger over the servo horn ones.
François Ubald Brien
