2. Primera prueba en bombillo / first light-bulb test
A project log for Generador Diodal ( Diodal Generator )
...aprovechar las cualidades fotovoltáicas de los diodos / take advantage of the photovoltaic properties of diodes...
chkymschkyms°> 04/05/2019 at 02:200 Comments
... 33 diodos Zener 1N (ST) 4148 conectados : 3 bloques en paralelo : 11 diodos en serie cada bloque...
...logró iluminar un LED azul pero con poco brillo...
...después pregunté en el blog ELECTRICALENGENEERING ( https://electronics.stackexchange.com/questions/428249/using-diode-as-a-solar-lightbulb-cell ) sobre el poco brillo del LED : RESPUESTA : si existe el voltaje (V) suficiente pero no la corriente (I)...
...33 Zener diodes 1N (ST) 4148 connected : 3 blocks in parallel : 11 diodes in series each block...
...was able to light a blue LED but really dim...
... then I asked in the blog ELECTRICALENGENEERING ( https://electronics.stackexchange.com/questions/428249/using-diode-as-a-solar-lightbulb-cell ) about the LED's dimness : ANSWER : enough voltage (V) but not current (I)...
