![](https://cdn.hackaday.io/images/6252191554758139735.jpg)
I'd like to get 3-4 days of use from the wearable; my assumption is that the MCU will stay in a deep sleep mode, unless 'interrupted' by the RTC (alarm/reminder) or push button (record an event).
I'd also like to go with a small battery. A LIR2032 or LIR2035 coin cell would work - except that I believe both are two large in diameter for the bracelet (they are 20 and 23 mm). The LIR1220 is a better option size-wise (12 mm) - I just don't know if:
- It will allow enough current to drive the haptic motor
- it will recharge in an adequate amount of time
- It will last 3 days assuming 20 alerts/events a day
Next step is to put together a quick proof of concept to validate my assumptions.
[Note - I originally referenced the wrong version of the batteries (CRXXXX instead of LIRXXXX)]
@K.C. Lee - Thanks for your comment - I'm definitely planning to use the LIR versions (I should update my documentation... I used CRXXXX instead of the correct name). I'll let you know how it goes.
The rechargable version (LIRxxxx) would be more suited than the disposable ones (CRxxxx).
The CR internal resistance is too high when you need more than a few mA and t loses too much capacity that way. You could help a bit with low ESR bulk caps, but much better of using that volume for larger Li-ion battery.
https://www.dmcinfo.com/Portals/0/Blog%20Files/High%20pulse%20drain%20impact%20on%20CR2032%20coin%20cell%20battery%20capacity.pdf
