Ultratronics Pro v1.0: Programming setup
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 12/18/2016 at 02:030 Comments
The Thor project I am building will be based on a Ultratronics Pro v1.0.
I do not have any experience with this board at this moment, so it is a wild jump into programming it as a Arduino Due.
This board is very similar to the populair Megatronics board, but it has much more power due to the 32-bit Atmega SAM3X8E clocked at 84Mhz.
Go to Boards manager
You can use the Arduino software to program it, but you must install "Arduino SAM Boards (32-bits ARM Cortex-M3) by Arduino version 1.6.9"
Now select the "Arduino Due (Programming Port)"
The controller board has 2 micro USB ports, one is the programming port the other one is a normal USB port.
I do not have any RAMPS yet to control my motors so I only tested with a on board LED blink and retrieve serial communication just like I would on a normal Arduino.
