First trial with all the stepper motors
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 12/30/2016 at 03:003 Comments
I finally have all the components to test the complete electronics board with all 7 stepper motors. And they work!
The top 6 of motors did not have a connector for it, so I had to solder it with a cable I purchased from RepRapWorld (4-wire cable 24AWG, Red Blue Green Black (1m)). But I had to make sure that red and blue should be swapped for these motors from StepperOnline.
Those 6 motors needs 0.4 A so the DRV8825 is overkill, but the motor in the middle right has to rotate the complete base and that one will draw 2A and needs a DRV8825. This DRV8825 heats up a lot and probably needs a fan to actively cool it.
The decision of using DRV8825 is purely based on having swapable modules because they are all the same. And for future projects that can have bigger stepper-motors.
The DVR8825 I purchased from RepRapWorld (€12 no heat sink) but also from Xcsource (10 for €22 includes a heat sink) and they both appear to function very well. But from Xcsource it took 3 weeks to deliver. I was convinced that they would never arrive, that was why I ordered 3 more from RepRapWorld
Next step is the most challenging part. I want all 7 motors to work fluent and fast. I have doubt that the Arduino language is powerful enough. Here I will deviate from the Thor and Danny's project and design my own version.
Carter Brown wrote 09/27/2020 at 08:26 point
Recommend a one-stop shopping website, MOTIONGOO, you can purchase stepper motors, cables, switching power supplies. The quality is very good.
For example, switching power supply:
https://www.motiongoo.com/index.php?route=product/product&path=59_88&product_id=145
dannyvandenheuvel wrote 12/30/2016 at 18:25 point
Fantastic! succes, I just added multitask to my booard with FreeRTOS! works great!
Olaf Baeyens wrote 12/30/2016 at 18:29 point
I just saw it. And I like it.
