Three cheers for Danny's ARTTOP_01
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 01/14/2017 at 01:491 Comment
Three cheers for the Thor modification by Danny at: 'Thor' robot with add-ons and GUI
The original ARTTOP_01 part required 8,5 hours of printing and probably 30% of the volume were support structures. My 3D printer always had big issues with a combination of ABS plastic, big objects and when it has a big volume of support structure.
The original print last week got warped so much that I had to terminate the print, then print the top halve and glue them together. (middle part)
Danny's modification ARTTOP_01_PARTS 1-2.ZIP has cut them in halves so I can print them separately with no support structures. Each halve takes 3,5 hours to print so it shaved off 1.5 hours from the original.
Top halve
Bottom halve
Both glued together as one perfect part.
Thanks Danny.
AngelLM wrote 01/14/2017 at 09:28 point
Amazing! I have never thought about that solution, glad to know it's solved :)
