to updatae soon
A project log for Automated IoT compost
Amalgamate is an automated composting system that helps users build a compost, download the code, and connect to a user interface
jamieJamie 10/20/2016 at 20:451 Comment
Currently this project is built and I used ngrok to connect to IoT without using port forwarding. I am working on figuring how much weight the composter can hold and still turn automatically and will update others one I know. I also want to add a weight sensor
manjuprasadmbasangi wrote 10/21/2016 at 09:26 point
You could use current sensor to measure the load of the motor to calculate the weight on the drum
this will be on trial and error method, but cheapest method
