Schematic
A project log for PewPew M4
A PewPew with a display.
deʃhipudeʃhipu 11/12/2019 at 12:080 Comments
Documentation is the hard part, not only because it's difficult to clearly describe everything, but also because it's hard to find the motivation. For instance, I never really needed a schematic for this device, since most connections are really straightforward, and obvious to me — but probably not to other people. So I have finally cleaned up the schematic view.
There isn't much in it, but it might help when you are trying to figure out what is connected where.
