This project is to implement a solution that can product a livestreaming device that will be able to send a stream to multiple livestreaming services like twitch and youtube at the same time.
This project will be using a raspberry pi along with a i2s mems microphone for audio and a IR camera for the actual video feed. The linux distribution will be generated using yocto to provide the smallest footprint and to provide a easy to setup image to use when attempting to reproduce.
For power it will be using a solar panel and a large capacity lithium ion battery.
