Test of PCB version 1.3
A project log for 16 Channel Thermocouple Multiplexer for Raspi
A auxiliary board capable of handling 16 thermocouples and passing their temperatures to a Raspberry Pi via SPI
piplaypiplay 12/09/2019 at 04:000 Comments
I have tested the V1.3 PCB and it works. My previous observation regarding the +/- symbols was in error and they are in fact the right way around. My next task is to design a enclosure to 3D print. At the moment I have the board inside the cardboard box that my Pi came in. To optimise performance you should minimise temperature gradients on the board. The best way to do this is to enclose it, even in a cardboard box!
