The rim wasn't quite even between the top/bottom thickness around the filaments. That bothered me, so I fixed it.
![](https://cdn.hackaday.io/images/3643541556755230762.png)
I was able to programatically create the rim based upon the filament pockets themselves, but the code was a real dog and the resulting model just made me feel dirty for creating it. I went back to manually doing it, and so this is just a couple cylinders fit to where the pockets need to be. It's not parametric, but it is about 100x faster and a much cleaner model.
Perhaps I'll figure out how to determine the cylinders needed for a proper parametric model later.
Stopped the print.. printing again..
