Printed two hubs, and cut 30 pieces of 80mm long string trimmer line.
Put them in.
![](https://cdn.hackaday.io/images/6172751556811605009.jpg)
Now, if I only had a robot to try them on. Anyone?
The line tended to curl as I was cutting it, which made getting 30 equal lengths a possible challenge. It also didn't help that this particular line literally came from my string trimmer as I changed out the line for some new stuff.
To solve the cutting a bunch of equal length sections problem, I came up with a simple solution of putting it inside a balloon handle (tube) bent over at the correct length, and then cutting them.
![](https://cdn.hackaday.io/images/3842571556815709661.jpg)
Worked well.
