I got a little rough with one of the rims, trying to bounce it off the floor and hit the ceiling. :)
It split where the filaments are pressed in.
I've increased the material thickness for this area in the model, but that won't get posted until I'm done adding back in some rim code. The #MPRT - Modified planetary robotics transmission version is nearly ready.
