Magnetic connector
A project log for The Airdrum - Make music while moving
Auditive and visual feedback with minimal effort in a modular package for everyone!
alessandro-verdiesenalessandro verdiesen 05/18/2019 at 19:350 Comments
Today we started with the R&D on our magnetic power and data connector for the panels.
The initial idea began some time ago with:
"How cool would it be to have magnetic connectors like those first macbook chargers"
In previous versions this wasn't needed because The Airdrum consisted of six panels which where all connected permanently. The Airdrum v3.0 is buillt modular, to meet this requirement we needed a magnetic connector.
We have looked at numerous possibilities but the most affordable would be to use commercially available parts. And since USB-C now also comes in magnetic forms, we gave it a try.
The connectors are magnetic USB-C qualcomm quick charge 3.0 certified and therefore have more pins then  the cheaper magnetic cables. This type has 10 connections in total. 5 on each side.
The Airdrum panels need at least 6 connections:
  1. VCC and Ground          ( 3-GND [black] , 3-VCC [red] )
  2. I2C                                 (1-SDA [Blue], 1-SCL [Yellow] )
  3. Audio Left and Right     (1-Left [Green], 1-Right [Purple] )
For convenience we've used the same wirecolors as the connections in the high-level overview of the project description.
