Log 1: Bumps along the road
A project log for WiFi Switch
Wall outlet adapter which can be controlled over the home wireless network
anuradha-gunawardhanaAnuradha Gunawardhana 06/02/2019 at 14:410 Comments
🛠 Bumps!!
During soldering I found out that I've made some mistakes on this version(V1) of the board and I correct them using the old fashion way.
Other than that I've encountered some issues when using the GPIO2 pin of the ESP8266-01 with the relay. When booting up GPIO2 output a small pulse, which activates the relay interrupting the booting of ESP module. this issue was resolved by changing the pin to GPIO3.
