Showing the Signals
A project log for Recreating the Jupiter Ace
Recreation of the 'Fastest computer in the Universe' that runs FORTH.
Cees MeijerCees Meijer 04/18/2021 at 20:020 Comments
My system works fine, but it appears that others are building my design too. And to assist in fault finding it is probably a good idea to document some signals  so other builders can compare their results with mine.
Oscillator
Oscillator output:
U23-8 Oscillator output 6.5Mhz
U9-6 (CNT3)
U10-6 (CNT6)
Z80 - Pin 6 - Clock input
U21-12 (FIELD) U19-11 (INT)
Video Section
Basis of the video signal is the 50Hz signal on U11-10. In the pictures below this is shown in the top, and used to sync the oscilloscope. Video signals were recorded with a LCD monitor connected.
U11-10 (50Hz) - U25-11 (Sync)
Base of Transistor Q5. Note the scale is 50mV/Div
Base of Transistor Q4 - ( VIDEO )
Cathode of D14, video output with a line of characters on the screen
Close up of video signal
