A microstrip to waveguide transition used for X-band waveguides. Manufactured with Oshpark FlexPCB
It is basically a fancy wire
x-gimp-gbr - 61.90 kB - 05/29/2019 at 06:23
x-gimp-gbr - 93.08 kB - 05/29/2019 at 06:23
drl - 5.45 kB - 05/29/2019 at 06:23
x-gimp-gbr - 287.00 bytes - 05/29/2019 at 06:23
kicad_pcb-bak - 207.92 kB - 05/29/2019 at 06:23
View all 14 files
So fairly certain this passes DRC since I ran it through OSH Park's initial input
TODO: remove soldermask and realign those large screw holes
View project log
View all 4 instructions
Pretty sure the bulk of the basic design of this project is done. I really need to try and do more of these. https://twitter.com/moddedLimes/status/1133453412291497985
Quinn
RobG
Andrew Marchment
tonyo
Yes, delete it Cancel
You are about to report the project "MSL to WR90/WG16", please tell us the reason.
