Future Goals (20190808)
A project log for PCB Decahedron
You can get 10 pcbs from most manufactures for cheap if they are under 100mm on each side. Let's make some shapes.
ian-shannon-weberIan Shannon Weber 08/09/2019 at 00:100 Comments
The next revision of this project will focus on the following points.
  1. I will use a regular polyhedron as a design point, likely a tetrahedron (4 sided die).
    1. This will simplify the side design and the jig design.
Initially this project was designed to compete in the beautiful hardware competition, but since the contest is coming to a close next week I will not be able to redesign and have everything manufactured in time. I will still keep this project in mind and will post again once it has made noticeable progress.
